- 8 Sep 2006
- uk
vertical tabs though on a landscape -Any suggestions for a replacement before I update?
with latest firefox build. can anyone tell me why they would change now bookmarks going directly into a normal list. they go by default into other bookmarks instead of how it used to be bookmarks menu ?
is there a way to change this by default ? so it puts all bookmarks straight to menu instead of other bookmarks. dont get the logic behind changing this![]()
Just tonight on these forums, I'm noticing very quick white flashing when navigating. Tried a system restart, but the problem persists.![]()
Narrowed the cause down to Ghostery. Disabling it fixes the flashing.Are you using hardware acceleration?
