No, Stelly is on about the Gen8's.
Correct! Just installed a HP P222 RAID card which is running like a dream
Stelly
I do live the P222's The Raid6 ADG codes are hard to find these days thou.
I'm really happy with my Gen10 but it's not used for much like you lot, it sits as a media server for Kodi (downstairs) as well as it uploads everything to the cloud for back up. Currently got 2x 6TB WD Reds in it in RAID1 and a SSD for the OS drive on W10 and it works very happily.
Stoner81.
Do you use the onboard Display Ports at all?
Want to know if they can output 4K resolution to my 4K TV. (via Windows 10 & Kodi, rather than DNLA, FreeNAS, etc, etc).
Very happy Gen8 owner, but as a home media user some of the features lost on the newer model don't concern me that much.
But as an aside is the fan noise comparable on the Gen10, i.e. it's about as loud as a Gen8?
I found it to be quite loud at first but having said that I didn't have anything previously so I'm probably the last person to listen tonow that I have had it a while I have gotten used to it so it's not that loud that it will drive you mad or whatever
