Is there any reason why an Xbox via RGB scart would give out a slightly softer blurry picture over that of a PS2 and GC with the same signal and tv?
Ps2 seems much sharper than my Xbox, maybe the cable is crap?
Where did you buy the cable from? I’ve had “fake” RGB cables before that were sold as RGB but were actually wired up as composite.
Somewhere in this thread is the technical explanation of plastic yellowing but in a nutshell it's the flame retardant chemical rising to the surface and you can buy/make your own bleach to strip it out the plastic.
It's all available from Amazon, I did think about it... but then I decided to ignore it and play on.![]()
Yeah that’s pretty much my understanding of it - I think it was an incorrect blend that was somehow causing it? And that some batches were more “incorrect” than others.
I have a SNES with a nasty yellowed bottom half but the top half is almost completely a brand new looking grey colour, parts never swapped round.
 I guess I'll have to buy one and see if it's any better!
