- 11 Oct 2007
Goddamnit. Spent ages looking at this, it's not a special edition. It looks like they light up as it's inlayed with clear plastic. I guess it just doesn't. At least I got the backplate and side to light up in red. Hopefully they will atleast fix trixx to support its LEDs at some point.Are you sure they're supposed too? Looking at Sapphires site only the Nitro 56 Limited Edition has the light up shroud, the standard Nitro 56 only has the light up backplate. If yours has two 8pins I would expect it to be the regular version with non RGB shroud.
You can easily check which version you have in GPUz, the Nitro 56 has a 1266MHz base clock and the Nitro LE has 1305Mhz.
Cheers for clarifying that.
