Dangerous game; you'll end up spending double your budget if you're not careful![]()
Tell me about it! Very very nearly signed up for a pre-reg m2 yesterday!
It doesn't really matter as you can get a Porsche Warranty added to either.
Aye had that clarified for me earlier - my only concern is buying a car that costs a lot to put in a condition that porsche will allow a warranty on it but...potentilly facing a saving of 5k which adds some float to that.
These are well built cars, you really should not be facing anything on a 981 outside of the cost of the 111 point check if you buy well. Also, make the 111 point check part of the deal, make it the sellers cost in that way you get a car, get Porsche to inspect it and get your backside covered. When I sold my GT3 the guy who bought it spent 300 quid (I think) getting Fearnsport to go over it with a fine tooth comb and I would have done the same. I've only speed read the thread so sorry if I am covering old ground.
My friend has just gone to renew a lapsed warranty on his 991 3 months after buying and the same dealer have now spotted a damaged crossmember (looks like a rising bollard) despite missing it on the 111 point check. So is paying about £750 to get it replaced before they will give warranty.
Don’t assume 111 check gets everything
'slightly'? It's nearly double! Amazing cars though! I wonder if a Tuscan is in budget?Slightly outside of budget, but I hear these are quite cheap to run.
a Sagaris is a dream car though.
