- 3 Mar 2006
- wakefield
I've got some full frame lens already so will weigh up my options I think.
what kit you got bud ?
Canon 750d
Sigma 70-200 2.8
Canon 24-105 l lens 1.4
Tokina 11-16 MK2 2.8
Sigma 24-70 2.8
Canon 100mm macro 2.8
Plus 2 kit lens- 50mm and 18-55
Speedlite 580ex
Love the lens I've got and wouldn't change them,would like another body and will sit down and see if it's worth it![]()
No trading outside of the members market dude![]()
See budPut in the members market and I'll have a look.
Thought it was time to upgrade my gimbal from the DJI osmo mobile to....
Perfect timing for my cruise to Vanuatu / New Caledonia in a few weeks
And, as i haven't posted in here for a long time, here's a couple of recent upgrades (within 6 weeks old).
To go with the rest of my current kit (minus osmo mobile now, but added Sigma 30mm F/1.4 + Rode videomic pro (Both not shown))...
Crane 2 is bigger and can house a dlsr You can control the zoom etc through it only canon though.So many Crane models now I’m very confused, what is this one and how does it compare to the Crane 2? Not to be confused with Crane V2.
A shame there was none in the show to try
have they released a firmware update to enable that?Crane 2 holds up to 3.2kg, this holds up to 2.5kg, you can also control the zoom on Sony, not just Canon. There's an app so you can set waypoints for time lapses, you can make it follow an object etc, it's a bit more advanced than the Crane 2, not to be confused with the 1 v2. I was debating the crane 2, but this suited my needs better with the extra features over the 2.
InnitIt seems every time I get an urge to get a gimbal a new crane surfaces. It’s hard to keep up with gimbal tech.
Can you post a pic on how small you can fold it?
How mich doe sthe gimbal weigh?
