- 26 Sep 2017
- In the Masonic Temple
It's colourful and cartoony so it will run better on nvidiaHow does it compare to the Nvidia cards?
It may or may not be the supply.
I was responding to Illuminist thinking it was the amps were the problem.
Ok glad that sorted that one, what drivers are you using? I'm in Gosport area so a little bit of a journey.Yes, i changed to the 64 bios (non LC) and all my problems went away, was even much faster than the LC bios, absolute bliss for a few weeks and then the PSU said "sorry mate too much for me im old"
I'm near guildford surrey, are you anywhere near?
Can you guys that i have quoted tell me how many amps on your 12v do you have?
My choice for a new , new one is either a kolink 1000 bronze, or a gamemax 1050 gm silver.. But any one that can suggest under £100 for a 800+watt psu with 70 ish amp 12v rail would be great.
Vega is such a power hungry monster, nomnomnom
100 for the block 40 for a pump £100-150 rad ..triple tubing connecters bout 45 ..Just snagged a 64 reference for £470.
I'm a bit of a watercooling noob (use a AIO on my CPU) but whats the best options for this? I've looked at EK but they seem to want to include the CPU in all their bundles and require a ridiculous add on for a 360 loop (like the A240R + 360 upgrade), people seem wary of the EK-MLC Phoenix kits which would allow for a 360 and gpu only loop and you can get caught on import duties there as well.
So what are people doing with these? How much would a dedicated 360 loop cost using separate parts bearing in mind being a newcomer? The only other 'easy' option seems to be the Alphacool Eiswolf 240 GPX Pro and that doesnt seem to be reviewed anywhere
Cheers for any help guys
you can cut that in half for second hand gear .. but will still need a new block
there getting better .. but once you get your bits you only ever have to change the block when you upgrade ..and I've been doing water for 10 yrs or more ..Cheers I'll keep an eye out on the MM. Don't really rate the kits then?![]()
started with 1 rad for cpu now I have 2xtriple and a quad .. also I don't use nickel as I use silver coils to keep the water clean
Oh thanks! I'll give it a searchI posted a vid earlier in the thread of a benchmark and temps if you are interested.
If i could pick your brains... would this combo work with me cutting in the Vega block?and I've been doing water for 10 yrs or more ..
not knowing anything about the kit .. I can't say .. pump speed strength ? slim is going to give you a rad about 20-25mm thick .. they do a pe version that's in-between which should be ok with varda fans at 1/2 speed ... quietIf i could pick your brains... would this combo work with me cutting in the Vega block?
My basket at Overclockers UK:
do some more research and cost out a diy kit .. in the end it's up to you ...
I’ve got the eiswolf. Very good, keeps my ref air at 50c max - running at 1650 ish with 1100 on the hbm. Fiddly to fit, took me about 90 mins being careful. I posted a vid earlier in the thread of a benchmark and temps if you are interested.
HTH!
