Heh, at least it's going to be gloss black. I could very easily put blue ontop lol
Put a stickerbomb wrap on top to **** Fox off
Be shaving the eyebrows next...![]()
I used to remember a bike friend of mine who spent thousands of pounds lightening his super bike only for him to be 22 stone. Would have saved a lot more getting membership at a gym!
Did the original Jag battery really weight 26.5Kgs? I know batteries are heavy, but I've lifted a few and I'd have guessed they weighed no more than about 10-15Kgs.
Either I'm eating more Weetabix or I'm just crap at guessing![]()
Got me looking at those batteries now! Mine is relocated into the boot but as it is so big it sits on top. If i got one these I could put it in the spare wheel well. How do they stack up to normal road use as they all seem to have real small AH?
Probably a 100Ah + battery they are over 20kg, it will be interesting to see how he gets on dropping down to a 50Ah as the draw from modern cars online infotainment systems is fairly high when the car is not in use but should be fine on a daily driver
Reduced the weight of the SVR by 22kg and the M3 by around 16kg with some very expensive lithium ion batteries that are very powerful, but weight next to nothing, RS30 weighed in at 4.5kg and ATX30 at 2.5kg.
RS30 is a powerhouse with 1200+ cranking amps, 50aH equivalent, also has restart technology and can be put into sleep mode and turned on via button combinations or enable restart mode if it runs out of power to start the car.
ATX30 is not as fancy, it has 880 cranking amps, 30aH capacity but does include restart technology, more than adequate for the M3, if anything overkill but no point in penny pinching when dropping a grand on batteries to save some kilo's.
Gonna look at losing the bracket for the M3 battery and just cable tie it down and save even more weight, will see if I can loose the tray it sits on too as all that weighs as much as new battery.![]()
I never heard of these smaller, lighter batteries before. These sounds awesome. Expensive, but, for cars with batteries in the boot, taking up space and weight, these sound ideal.
Can you get slimmer versions?
They come in various shape and sizes, as long as your close to required cranking amps for your engine and understand capacity (aH) your good to go. Then their is regular lead acid (cheapest), AGM (moderate expensive) and finally lithium ion which is best quality and lightest, but also the most expensive.
