Do you've a photo with stickers and without? Would be interesting to compare between the two.Thanks guys, was debating the stickers and have removed them now, looks better without.
Ruining your chain with wax?Picked up a big can of WD40 chain wax from the local bike shop. £9, and it came with a big can of WD40 chain cleaner.
I know what I’m doing today![]()
Castrol racing lube.What’s best for a chain for a bike using for commuting. As from this afternoon, I need some.
My Castrol racing lube ran out and I’d heard good things about the waxRuining your chain with wax?![]()
My Castrol racing lube ran out and I’d heard good things about the wax![]()
FTFYYeah if you're commuting decent miles a scottoiler is second to shaft drive
Fitted a new phone/GPS mount. Tenner from eBay. Been out for a spin and it works brilliantly.![]()
Got massive amounts of brake lever travel following a brake fluid change. They've been bleed to buggery but still nothing. I've read about removing calipers and resetting the piston position closer as there could be too big a gap between pad and disc at resting if that sounds plausible? Anyone got any other ideas?
