- 29 Jul 2004
Actually its on you to prove that the west is funding ISIS, quite a fanciful claim that, borderline lunacy really.Keep on proving it, Jacky-me-lad.
Get more info. Find some perspective.
ah... just saw the Alex Jones rant... if you want an explanation for the above poster's rather weird POV (the UK/US, France are now supporting ISIS, wat??? Turn off main stream media etc..) just keep in mind he watches info wars - Alex Jones has lost his **** and it is quite funny to watch
An Iranian military base in Syria was targeted by unidentified aircraft Saturday night, Syrian media is reporting.
The Iranian base, located in the Jabal Azzan region south of Aleppo, is the largest in the country. Eyewitnesses are reported to have observed explosions and flames at the site.
Other unconfirmed sources have identified the planes as Israeli fighter jets.
http://www.jpost.com/Breaking-News/Syrian-media-Explosions-at-largest-Iranian-base-in-Syria-549824
Surely this is where someone says FALSE FLAG!!...?Unconfirmed:
Chlorine reacts inside the lungs forming hydrochloric acid and causing severe burns. Many die months and years later as evidenced in the first world war. What else do you need to be, not to be a chemical weapon. As it is weaponised, put into shell / bomb casings, it is definitely a chemical weapon.
Chlorine Gas can be made by anyone at home with stuff from ASDA.
There are youtube vdeos on how to make it and instructions available on the internet, only 5 steps to make it seems!
Yes it reacts nastitly with humans but given its used in many industries (you even have some im your house) its not classes as a chemical weapon same way sulphuric acid in your car battery isn't.
So it's not covered by investigations which is why it has been used.
If chlorine was declared a chemical weapon it would be a nightmare for industry around the world to try and secure it.
Yes, but then you put it in a shell casing with a propellant aim it at your opponents and it is a chemical weapon. It may not be on a schedule by OPCW but that is semantics in my opinion. You have to be a right ******* to even think about deployment in any theatre leave alone a civilian population. There are no excuses IMO.
I don't think it was pointless to react to the use of chemical weapons by striking chemical weapons storage facilities and a research centre - it is the fact they were used that needed a reaction. Sure chlorine itself has other uses and possessing chlorine isn't a problem in a general sense.
The willingness to use chemical weapons though is worrying and responding to that is right, targeting facilities used to develop and store chemical weapons is appropriate.
It is supposed to be chlorine and sarin that were used btw...
But we have already established these faculties were empty by inspection though
not necessarily, how was the research centre empty for example?
ISIS are the west's assets on the ground. You're seeing things inverted, as you've been programmed to.
False flag.https://www.gov.uk/government/news/update-air-strikes-against-daesh#history
https://www.gov.uk/government/publi...t/raf-air-strikes-in-iraq-and-syria-july-2017
Oh sorry, all those bombings against Daesh targets must be the "token airstrikes" you were on about![]()
while in Syria 22 enemy combatants were reported killed and four injured between December 2015 and March 2016.
https://news.vice.com/article/exclu...almost-1000-enemy-combatants-but-no-civilians
22 terrorists in four months is hardly a serious fight against Daesh in Syria.
In any case, all these numbers are impossible to verify.
You'd have to define what we mean by research center tbh.
Was it inspected or was it hidden from thbe insoection?
If it was inspected then surely it's empty or operating like ours purely on an analysis and countermeasure basis.
I can't really see Syria running its own development program of new chemical weapons at this point that more the peacetime thing of massive nations.
22 by the UK. Just goes to show we're not targeting just any runt on the ground, but ISIS command with precise munitions. Mind you,if the number was 2222, you'd be bleating that we're blood thirsty tyrants wasting tax payers money dropping so many bombs. Either way, more moot rambling from russiabot.
