Do you guys play regularly on discord? BF1 is my favourite FPS on console. I’m PC gaming again now so tempted to see how much better it looks.
I'm off work this week so will pop online and see if people are playing.
All sounds good to me. I regularly switch between the classes as I find it more fun. Although I mainly play assault or iron sights scout. Really enjoy some of the medic guns, class allows you to play insanely aggressively.
Okay, cool will add you. My name is milkychaos.
You guys use the OCUK discord?
Does anyone else think the MG15 low weight is a bit OP? I recently started using it to unlock something else but it seems laser accurate and kills quite quickly.
If you think that gun is OP, try the LMG 08/18And then it gets even more OP if you bipod it. It gets me squealing like a little girl when I've set down the bipod and playing the angles, killing infy 500 yards away with my lazer bullets.
Funny enough I was using that but came back after a few weeks and found it not as good. Now the MG15 feels a lot better. Which version do you use?
