Duckduckgo privacy essentials.
thanks (need to review existing add-on before I finally take the Quantum jump)Duckduckgo privacy essentials.
Still going strong, some more detail for ppl who want to make the switch:
Extensions:
- uBlock Origin (ad blocker, works on mobile)
- DuckDuckGo Privacy Essentials (visible privacy rating, https everywhere, tracking blocker, doesn't work on mobile)
Settings:
- Tracking Protection ON, with Strict blocklist (tracking blocker, works on mobile)
Exactly. If you have DuckDuckGo extension installed there's no need to also have HTTPS Everywhere.If DDG does the same as HTTPS Everywhere no need to have that installed if I have currently?
so with this, everything is compartmentalised, no sites access cookies from other domains, if, that is, you permit a cookie to be created at all, for that domain, with DDG or FF whitelist.- First Party Isolation ON
Yeah, but personally I haven't seen anything break yet, like.. at all.so with this, everything is compartmentalised, no sites access cookies from other domains, if, that is, you permit a cookie to be created at all, for that domain, with DDG or FF whitelist.
The only con seems to be google where a google domain cookie enables utube logon too.
I badly worded that -
with the draconian add-on signing with the newer ff versions, I suspect they may soon clear-out/delete these older add-ons, especially since they will no longer be compatible with >=57
so if I need to re-install pre-57 firefoxes, I will need to archive the compatible add-ons.
The older FF's, providing you have demand loading of tabs is already economic on memory, and the diet I recently gave chrome, 'The great Discarder' add-on, works well.
there are a bout 40loaded tabs in Firefox, 20 in waterfox and 10 in chrome - but I am probably not typical.
Advantages over The Great Suspender:
- More memory savings
- Compatible with chrome tab syncing
- Super lightweight extension that uses no content scripts or persistent background scripts
Disadvantages over The Great Suspender:
- No visibility on which tabs have been suspended
- Unable to prevent a tab from reloading when it gains focus
for me, in chrome, the great discarder, reloads all the tabs which then go to sleep after 30 minutes if not used."Does this remember if tabs are discarded on shutdown so they stay discarded on startup? If no my chrome with over 150 tabs will use insane memory on startup and load slowly."
Apparently v60 is on its way with "promoted links" on the new tab pagev59.0.3 just came through, compatability for the new Win 10 Spring update.
[Feature/Bug causing the regression]: MS changes broke this; our code's been doing the wrong thing, previously harmlessly, for years now, tho
