Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
You’ll need much bigger bags or pelican case to hold all those lenses!
Then just buy your lenses in stages you don't need to get them all at once. Take your time, read reviews, and choose carefully as and when you identify a need.
Looks to me like you have more lenses than you needed with M43 anyway.![]()
You’re pretty balls deep in M43, it’s going to be eye watering to move.
I’m not so bad, got a GX8 and GX85 along with:
- Oly 12-40mm f2.8
- Pana-Leica 25mm f1.4
- Oly 45mm f1.8
- Oly 75mm f1.7
- Oly 9-18mm
- Pana 14-140mm II
The thought of moving and the cost involved is pretty hard to get around.
Maybe but I don’t really ave any cross over. And I’m a sucker for quality primes
I know I won’t swap all at the same time but it’s the question of which 3 or 4 I get with my £5k and then add some more later as and when. Dilemmas
The bokeh on those "slower" lenses will still be faster than your 1.2, you'll likely be blown away by the difference.
Isn't 25mm 1.2 on M43 essentially like 50mm f2.4 on full frame anyway because of the 2.0x crop factor?
Not only will the above lenses provie much better DOF, but the low light capability is what really blows you away when switching to full frame from a significantly smaller sensor like M43.
Will you lose an Olympus-only camera feature? Yes.Yeah which is why I'm looking at swapping. Even the lenses I have at 2.8 will be better at f4 on the Sony as far as dof goes plus the Sony has much better iso.
Which is why I might settle on f4 for the telephoto lenses. Saves weight plus lots of cost
Out I interest I presume I will lose live composite moving to the Sony?
Wasn't sure if live composite was Olympus only....
Is that like iPhone's panorama stitching?
No it’s for when using long shutter speeds. You start the exposure and watch it develop on the screen then simply stop it when you’re happy with the exposure achieved.
no, more like f5.6Yeah which is why I'm looking at swapping. Even the lenses I have at 2.8 will be better at f4 on the Sony as far as dof goes plus the Sony has much better iso.
Even better than that is that you can take an exposure and leave it so it only adds new light sources without affecting the original exposure. Great for light trails and light painting.
I will miss that and the boom to astrophotography. Will also miss 60fps and pro capture taking 20 shots before you press the shutter,
Suppose I will lose photo stacking and hi res pics as well?
Oh well pros and cons I suppose.
I'm sure you cam make a feature pro's and cons list comparison yourself on paper to see exactly what you lose and gain.Even better than that is that you can take an exposure and leave it so it only adds new light sources without affecting the original exposure. Great for light trails and light painting.
