I don't understand the guff about stock coolers. I've used loads of Intel stock coolers over the years and they've been absolutely fine for running the CPU at stock. Obviously AMD's later ones are much better, but that's only making up for their abysmal ones during the prior generations that sounded like a hoover.
Ah ok, i thought the 8400 didn't come with a stock cooler.... yeah fair enough, but lets be honest, the Ryzen Box cooler is a good quality cooler thats capable and quiet, capable enough to run a good overclock on the 2600, its a comfortably usable cooler.
Intel's coolers are junk, you wouldn't actually use it unless as a stop gap to buying one.
The 8400 can't be overclocked, you'd just use the stock cooler regardless of its quality.
Intels stock cooler is much more likely going to throttle on you under heavy loads in a hot environment, heck i see it here with the quad core i5s in crap HP and dell machines sometimes.
Anyone know how to role back Arma III builds? 'Arma3Legacy###' Steam code no longer works, damn it! :O i want to test the Ryzen patch vs pre-patch.
and they are always slow with update patches so i had to role back often.The 8400 can't be overclocked, you'd just use the stock cooler regardless of its quality.
Couldn't agree more with this comment I read as well "
For the price you pay for the premium ram, new cooler, and mobo for the ryzen 2600 oc, you can buy an i7 8700."
In order to get the best out of Ryzen you will always need expensive high speed RAM. Until RAM is cheap again Intel is still the better option for gaming.
I agree, you'd have to me a massive AMD fanboy if purchasing this just for gaming. Completely negates the whole value argument.
If you don't like your ears.
The 8700 is £120 more expensive and also not overclockable, if you put 8700 and 8400 results side by side IMO you're not going to find much difference, i would bet they are quite similar and the 2600 when overclocked is solidly faster than the 8400 so with that at least equal to the 8700 for £120 less.
The 8400 or the 8700 cannot be reasoned over the 2600.
I've never understood this. Every single Intel stock cooler I've used is quiet (That said the first Intel stock cooler I used was for an E5200) whereas the same cannot be said of AMD (Until recently)
You need a decent board for that 2600. There are numerous reports of it not overclocking well on a b350 board. Add in the increased ram cost. I'd like to see how the 2600 does in an mmo like guild wars or wow against the i5. Can't wait for faster Gpus to arrive!
No you don't and no there aren't. my board is a £75 board.
