Lol, don't worry, good to know for the futuredirectly over the alex drawers? it'll be fine. ive stood on those before to reach the top of a cupboard.
edit - oops old post.
The case is 18KG empty, then I'm fully water cooling with 3 rads, heavy GPU block, heavy CPU block, large heavy glass reservoir (690ml fluid capacity) plus that's about 2ltrs of fluid for the whole loop, an E-ATX motherboard with heavy metal rear shield, 11 fans, fan controller, approx 15-20 brass fittings, tubing, 850w EVGA PSU, Braided PSU cables, 2 HDDs (3TB).... So it's an estimate I made of 35KG but an educated guess and I'm confident not too far off35kg? Are you being serious?
Edit:-that was for spacemonkey
what desk is this and where can i buy it?New desk, need to sort some cable management out.
What desk is this mate?New house (last May) new mancave = new desk....
what desk is this and where can i buy it?![]()
IMG-20180426-WA0000 by Stuart Pardue, on FlickrNice but definitely get a different chair.Here's my desk which is made up of two white Ikea Alex drawers and a 1.8m length of Duropal block effect worktop.
The case is 18KG empty, then I'm fully water cooling with 3 rads, heavy GPU block, heavy CPU block, large heavy glass reservoir (690ml fluid capacity) plus that's about 2ltrs of fluid for the whole loop, an E-ATX motherboard with heavy metal rear shield, 11 fans, fan controller, approx 15-20 brass fittings, tubing, 850w EVGA PSU, Braided PSU cables, 2 HDDs (3TB).... So it's an estimate I made of 35KG but an educated guess and I'm confident not too far off![]()
Are you secretly Zaphod Beeblebrox @Dicehunter ?![]()
From this:
To this
(I do have a windowed panel now, I just like it off though haha)
Spectrus that 750D looks really nice, and those speakers are huge! Nice setup man![]()
For those of you using the IKEA Alex drawers along with the Karlby Worktop, do you think the setup will support a heavy PC case over the right hand side drawer? My case fully loaded is likely to be around 35KG? It's the Phanteks Enthoo Primo fully water cooled.
That's just the base unit, I'll also have a screen, speakers etc... + an A3 printer on the left side.
Thanks![]()
