Looking to upgrade my home network and have narrowed my shopping list down to the following (probably a typical list for a home setup);
Is there anything I should watch out for? Any gotchas? I'm planning to ceiling mount the APs (cable running issues not withstanding) and use POE. I have 200/20 FTTP via BT and have an OpenReach ONT. I'd like to create separate wireless networks for various groups of devices (Sonos, Smart Home tech, kids devices, etc) and I use IPv6.
- 2 x UAP-AC-Lite Access Points
- 1 x US-8-60W Managed Switch
- 1 x USG
- 1 x Cloud Key
There are lots of threads on the UBNT Unifi forums about IP v6. I would strongly suggest that you research that aspect of the project before you sink £100+ into a USG. Everything else looks fine. They US-8-60W is only 4 ports PoE and you will need to make sure you get the very latest AP-AC-Lites to make sure they are 48V because the US-8-60W cannot Power 24V Unifi Access points. Which is bizarre, but that’s how it is. Anything made in the last year will 100% be compatible. If you’re shy of ceiling-mounting then can I suggest you take a look at the AP-AC-IW? It’s an AP-AC-Lite in a wall-mounted format and it has the extra bonus of giving two RJ45 1GbE connections at the access point, one of which is PoE so you can power a US-8 if you need more switching capacity.
It also might be worth keeping an eye open in Member’s Market over the next 24 hours
