Great looking ribs Raymond, wish I could have such great photos of my bbq efforts.
The cheap Waitrose short ribs are on
FireBoard link for those who would like to see how it works - https://share.fireboard.io/AA5735
By the time you have bought all the bits for that it's almost 1/2 a big green egg (depending on what you tell the wife!)..
Mine is a lot thicker than yours, you picked the thin ones!
What internal temp did you get to @thewanted ? Looks like quite a light amount of rub but you've still ended up with a very solid bark there.
While no doubt you can get better brands, Id use it if it was a gift. Just buy a bigger cover that will fit it and use it and I am sure it will be fine for you. Will make the bbq more enjoyable for her as she got it for you. (Or you could tell her it has a missing piece and has to go back - darn it, but dont worry you can go to the shop together to pick the replacement....)What're peoples thoughts on this? My wifes just bought it me for an early fathers day gift (and a house warming gift since we'll have a decent garden). I had intended to get a Weber or similar. She has mentioned she'd be ok if i returned it but that'd incur return costs and i'd feel a bit of a dick as i know she'll have spent a while looking for one which looked good.
https://www.wayfair.co.uk/garden/pdp/homcom-charcoal-barbecue-with-side-shelf-iv-hmcm1022.html
There's no mention of any warranty which i generally look for as a sign of quality, it's likely to only be used for generic food rather than anything too extreme, but it is likely to be left outside all year round and i'm not sure how easy it'd be to find a cover due to the side shelves.
Also would it be better to have a vent in the bottom too (can't see one) or is it ok to just be in the top?
Also now to go buy a chimney starter. I presume they're much of a muchness. Should i just grab one from Amazon?
