- 22 Mar 2004
Yeah. I didn't notice it until the 1st pen. A bit disappointing.
Got the same problem with my Samsung KS7000 - TV isn't on the supported list on the BBC website so I've bought a Roku Streaming stick+ and it's been perfect. One thing I know for sure is I won't be getting a Samsung ever again.
I thought that too, but I don't have an hlg tv - so need to check if that's what happens if you watch in sdr.Seemed a little dark/muddy perhaps, but not sure if that’s down to the weather maybe
but you have seen the link in the past ? is it running iplayer beta.?Switched onto the France game but didn't notice a 4k link or anything
Panning shots seemed much smoother than I have seen before.
When you select the World Cup, it should give the option of UHD, HD or SD before continuing depending on the app you’re using as to whether it supports or not.Not sure, I have a choice of either the iplayer on fire tv(latest uk one) or built in to tv. Will have a look.
Don't want to buy a stick just for 4k bbc I-player Although I am considering apple TV 4k... Does that do 4k iplayer?
Wasn’t noticeably any better than normal HD imo.
It seemed a bit dim on my B6 OLED
Others have reported the same. HDR normally looks great.
