- 3 Jul 2018
HAH! I tipped my PC over today so the card is vertical, and guess what? No noise. Certainly I can confirm that for my 1070 Gigabytes testing is inadequate. The card needs to be horizontal, with the fan pointing down, as we suspected, for the noise to occur.
Same thing here, stopped one fan while under load and the noise stopped, did the same with the other and it also stopped so I'm not sure which it is at this point. Also tilting the card caused the noise to stop, same as it was on the test bench. I'm disappointed that as an RMA centre an issue that seems like its on more than just my card wasn't checked a little more, or that they didn't seem to try to reproduce the issue. Seems as if they whacked it on a test bench and called it a day when it didn't make a noise.
@GIGA-Man Any advice on where to go from here?
I've got some arctic cooling USB fans that are fine when vertical but if angled horizontally they start ticking after awhile at certain speeds - short of replacing the fans entirely not much can be done :s
