- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Both of these are a problem. First issue is it is too wide to fit in the rear section and it cannot be mounted front side either as my other rad/fans gets in the way. So for the vertical mount max size that can be fitted is 40mm when using dual 360mm rads.
I'm switching to a 40mm thick rad for the vertical mounted position, that will fix the issue.
