Caporegime
- 21 Jun 2006
I am using Molino Grassi Italian Flour its 00 flour comes in a red and white bag you can get it on amazon for about £11 for 10 1 kg bags. When i take it out of the fridge i leave it to come back to room temp 2-3 hours before i need it. This is my rough process from start to finish. I also use a kenwood chef as well to mix it all together.
Put dry ingredients in the mixing bowl
Add yeast/water/oil in jug and mix well, pour into the flour with the speed low until you get a ball of dough.
Turn speed to 4 and leave it for 10 mins.
Take out of the mixing bowl, and cut into 200g chunks an ball it up. (200g is about the right size for what i need for my pizza oven) doesn't have to be exact a few grams either way doesn't matter too much.
Either have a large tub or small tubs and put balls in fridge, if using a large tub make sure there is some space to grow.
Cover well with cling film and leave for as long as you like.
Get out of fridge and leave 2-3 hours room temp before you need it, as it will grow.
If your not cold proving, i would basically do the same up till the balling stage, and then leave them wrapped up in a warm area for 3-5 hours.
that is the flour i use.
so you never room temp prove for hours before putting in fridge. you cold prove then room temp prove or room temp prove and use that day.
which is why i'm having issues with leftover dough that has been proved. okay will make sure any that may be left over is stuck straight in the fridge straight after mixing. leave the rest to be used that day and if i need more i can always take out the stuff from the fridge and let it sit out for an hour or two.
