The crosstalk solutions video review is ancient, and a guy who installs UniFi products for a living is hardly a reliable independent reviewer. I wonder why he hasn't done a more recent review.....
He’s probably working on the basis that if you can’t say anything nice, don’t say anything at all.
Also as I've mentioned to you before the AmpliFi router runs modified firmware from the UniFi AC AP's as it has the same SoC, so it offers very similar performance. It even has a similar antenna array to the AC LR AP.
What? It has a disc shaped array that fires down and out from a ceiling mounted position? The two arrays are nothing like each other. From the Crosstalk Solutions video you can see how utterly incorrect your statement is. The whole basis of the review is he has the base units next to each other but the Amplifi unit simply doesn’t go as far. No amount of firmware updates will make it transmit or receive better. The amplifiers and antennae can only transmit at the legal maximum and receive in the orientation they are arranged in. There is absolutely no way the Amplifi units can transmit at anything like the AP-AC-LR. It’s simply outrageous to suggest that. Amplifi even had its own base and LR versions at one point. What happened to them? Oh wait, they were abandoned with no further updates. It doesn’t give me a warm feeling about Amplifi HDs future.
AmpliFi is getting UNMS support later in the year and has also entered into the core range as the Air Cube. Also as stated before AmpliFi has it's own separate forum.
Are you saying the £60 Aircube AC is the base Amplifi, the Amplifi LR or the only one actually available in the UK which is the £120 Amplifi HD? Because you only have to compare the chipsets and capabilities to see its nonsense. Aircube AC is the same chipset setup as the AP-AC-Lite with a significantly poorer antenna array. It’s not a mesh unit and doesn’t work as such. It’s basically a cheap Wi-fi router for ISPs who use UBNTs AirMax long range WLAN Systems to sell or give away to home owners who sign up for Ethernet over long range WLAN.
And why exactly does Amplifi not have forums with the core UBNT product range? The Aircube has its forum within AirMax. So why doesn’t Amplifi? Simple answer? It’s not a core UBNT product. It’s a spin-off. And the ‘community’ on those forums isn’t exactly a hotbed of activity. Last post on the general discussion forums was about 3 weeks ago with the problems forum being a bit more active with the last post 4 days ago. Tumbleweed blows through there more often than folks post.
It's a decent consumer product that is reliable with good performance. "Steaming pile of Poo" it most certainly is not.
It’s the worst or second worst of the Orbi type home mesh systems. If you want something good, get Unifi. If you want something with support and a long-ish term future, buy Orbi.
