- 31 Oct 2012
- Edinburgh
Sad to see them goIt seems Hardware.fr has shut down:
https://translate.googleusercontent...700201&usg=ALkJrhidYMw-c4PJA7Jqlhqh9sFWncTzQw
A shame!
A shame!
The company is owned mostly by AMD, but it's a bit worrying since China has a tendency to steal IP.China Finds Zen: Begins Production Of x86 Processors Based On AMD's IP https://www.tomshardware.com/news/china-zen-x86-processor-dryhana,37417.html
I built my son a pc using the 2200g and using the on board gpu.
It's not a bad little processor and has worked fine with every game he has thrown at it so far.
I went for the gigabyte ab350m gaming 3 and 8gb 3000mhz ram
Hey, I knew our sons had similar systems, but I didn't realise they were identical in terms of board and RAM as well. Working well for my lad too.
@Journey - those are some nice overclocking results on stock cooling! What your chip and VRM temperatures like? And what are you using for stability testing the iGPU?
And did you say no thermal paste?!![]()
It's not my sons, but was built for a good friend of mine who hasn't had much luck of recent so was a surprise for him.![]()
I can't tell you the temps of the VRM, but they are pretty hot. I am in the process of finding a small heat sink I can cut down to fit them, which should allow a bit more headroom on the iGPU overclock. For stress testing it used a bit of OCCT, and a loop of Unigine Heaven, took a good few hours of tinkering to get the right volts/clocks but was well worth the effort.
Yes, no thermal paste due to a miscommunication which I found out only after doing all of the testingIt was still running reasonably cool, but Ryzen CPU's are very cool running, but once I get it back I'm going to put decent paste on it.
If you've managed okay on stock cooling, though, I might try some more modest 1500MHz+ iGPU clocking and see how it goes.
Did you change anything else other than the SoC and GPU voltages?
I'm just going to Dremel a couple of old GPU RAM sinks I have kicking around my spares box, and put them on with some of the 9448A 3M thermal adhesive tape, as those sinks you linked are way to expensive for my liking. If you look on Aliexpress, you can get a 12 pack of heat sinks in various sizes for $2.86 + $0.25 shipping, they'll take about 30 days to get here though, oh they already have tape on too.
I left the CPU clock at stock, and just upped the iGPU to 1.3v and 1600MHz to start, and put the SoC voltage to 1.1625v and went from there. Don't forget most of these APU's have a frequency black-hole from about 1350-1500MHz, so try above 1500MHz or you may not have much luck.
As you already know, the biggest difference is the RAM timings and speed, so get it running as fast/tight as you possibly can. I couldn't get 3600MHz fully stable at C16, so dropped to 3333MHz C14 VLL and that brought the biggest performance uplift. When I get more time with it, I'll grab some exact details and benchmarks.
Anyone want 10-15% IPC boost and up to 16 cores for Zen 2?
Ipc bump yes, though 16 cores is a bit overkill for regular desktops yet.
Ahaha, imagine 10-15% IPC uplift, 10% frequency bump and 100% the cores count bump
