I wonder if yours does take salt
As I saw this review below written on amazon uk
It was! Not afraid to say I asked the Mrs to helpGood job! I bet that is really heavy.
snip
It is! Just slightly short in barrel lengthbut works for me. Very easy to fit.Is that a gatemate long throw lock? Had mine a couple of years, silicone spray lubricant works really well to keep the mechanism nice and smooth.
WD40 isn't a proper lubricant, so a dedicated lubricant is a wise choice.It is! Just slightly short in barrel lengthbut works for me. Very easy to fit.
Does wd40 work also?
Looks like a very good job! Even braced correctly and everything.Bought lots of timber to make a gate and fence. Also bought a lock which can work both sides, and a skip..ignore the brickwork and electrics I need to tidy up..
About half of the timber here (what's left after making the below fence )
First time ever making a gate and hanging a door, but the result is pretty good!
I've heard that the cooling is so bad the I9 can't run at stock frequency.
No your model doesn't look like it has the salt chlorinator. I got the hydrojet one last year and I have an extra button between the water filter activation and power timer buttons.I think all palm springs hydrojet models have the salt function and the salt goes into the main pool after filling, all 2Kg of it!
Has to be pure 99.9% pure salt!
It’s actually a cost option the flat bottomed steering wheel, at £100, which I found really surprising.
What does a flat bottom do?
more room for your knees?
Makes steering with your knees as you shave and eat bacon MUCH harder.....I believe.more room for your knees?
