Yep Crius II
Did you have it wicked correctly? Leaking is mainly due to too little wick in the coil.
Get it out the bin and give it another go man, you're missing out. It's a great tank.
Yep Crius II
And any recommened online shops I can get 3mg juice from would be great
Yours, Vape Noob
https://vapewild.euGuys
I have an iStick Pico with a Melo 3 mini I've screwed with the settings, is there anyway I can "factory reset" it?
Also I need some coils for it currently has a 0.3 (30/80w) coil but @ 25w can burn the back of my throat should I go for a 0.5?
Yours, Vape Noob
Yours, Vape Noob
Ultimately bottle shots are the way to go-250ml, 4x10ml 18mg nic shots and top up the bottle with VG shake it and leave it to steep recommended time which is usually 7 days for fruit flavours outlay probably costs about £15 for 250ml of juice.
Hi, I'm thinking of getting a Geekvape Blade but do anyone know a good legit websites to order one from? Thanks.
PS - Any suggestions welcome.
Sorry what does PG or VG stand for... I'm a novice vaper...You probably need more PG to thin it out. 80VG may struggle.
OK thanks, so should I be looking at 0.5 for a coil or 0.3, that something else that confuses me ...Vegatable Glycerine and Propelyne Glycol, some tanks/atomisers will struggle with high VG liquid as its thicker. Generally more VG = thicker liquid with more clouds and smoother. More PG its more viscous, wicks easier, can give more flavour and has more of a throat hit.
Coil might be knackered or it cant handle 80/20 or its crap liquid.![]()
Ecigone or if you don't mind waiting, Fasttech have them.
OK will have a readHave a read.
https://www.ecigarettedirect.co.uk/ashtray-blog/2015/02/voltage-watts-ohms-vapers.html
That tank/coil may just not be able to handle that juice.
Its a iStick Pico with a Melo 3 mini, I'll pop back there tomorrow Liberty Flights in Watford.. They seem like cool guys I'll go have a chat with themThe resistance wont make a difference if your juice is too thick, as it won't wick fast enough. If anything the 0.3 will potentially burn out quicker. Where did you get your juice from? If it's from a store I'd be taking it back and asking why they sold you an 80VG juice in a tank that's clearly not suitable.
If it's the Eleaf ELLO, you want a 50/50 juice in that, maybe 60/40 in this heat.
Its a iStick Pico with a Melo 3 mini, I'll pop back there tomorrow Liberty Flights in Watford.. They seem like cool guys I'll go have a chat with them![]()
Hmmmm and what do you have now?I had one of those for a bit, in a drawer now, worked fine on all my juices at the time which were either 50/50 or 60/40.![]()
