***** RED FRIDAY SALE (BLACK FRIDAY BUT EARLY!!) *****
6 Mar 2018
Ordered the 8086k bundle..... Couldn't resist. :eek:
Along with the last EK RGB Founder's Edition 1080 water block you had in stock which was also £20 off. :p
13 Jan 2018
- Intel Core i7 8086K Anniversary Edition CPU - Guaranteed CPU overclock of 5.0GHz on every core
Can I check on this bundle does this mean all 6 cores running at 5Ghz at the same time?
Thinking of this to upgrade my 7600k
5 Dec 2011
The profiles to OC the 8Pack bundle are here just load the CMO from a USB drive in the OC Profiles section within Tools Tab in Bios:
4000mhz mems https://we.tl/mR51C3yG2h
3800mhz mems https://we.tl/KqJOkH5cKf
3600mhz mems https://we.tl/HbhvrHJw8e
Please flash to this Bios first using the EZ Flash Tab within tools and a USB stick:
https://we.tl/FCBQ5f0EJ5
I want to buy the 8086@5Ghz bundle but it has been along time since I have done any overclocking. Am I correct in saying the cores are all already overclocked to 5Ghz and all I need to do is flash the Bios first and use a profile to clock the RAM?
OcUK Staff
20 Feb 2012
John Smiths Stadium
Down clock if you have windows power plan set at balance.... But who actually cares about this?? 5g desk top is essential..
The cpu at stock is only single core turbo 5g so the profile sets all cores, cache, power limits, ram, io, sa, standby all that stuff too.
Some cpu IMC can't do 4000mhz on 4 dimm board hence the other profiles.
6 Mar 2018
This t
7600k is what I'm upgrading from. As I've already bought the bundle.
Cannot wait to get this chip installed and in my custom loop. But I'm away on holiday so won't get to touch it for at least 5 days after it gets delivered. :(
Then it's time to play around in bios and the fun with benchmarking and blue screens can begin. :p
Is it wierd I prefer benching to gaming? :eek:
14 Apr 2007
Think i'm all set for ordering. @Gibbo any final thoughts before I pull the trigger?
My basket at Overclockers UK:
Total: £996.96 (includes shipping: £0.00)
Fractal Design Define C TG has glowing reviews - possibly the best case of 2017?
White theme as it matches my current GPU, fans included in the case and RGB on the motherboard. My SSD's will be hidden in the rear, so the only white braided cables i'll need are motherboard + CPU + GPU - Phanteks kit looks perfect?
Bitfenix white LED strip to brighten the case up :)
OcUK Staff
OP
17 Oct 2002
OcUK HQ
Looks good, did you order?
26 Jul 2018
Just received the Intel bundle this morning. The cooler has thermal paste pre-applied so since it included the thermal grizzly stuff I guess it would make sense to remove the stuff already on? And would you recommend spreading it like the packet says or just using the pea/line method?
