My Samsung HBM on the V64 doesn't go over 1060. So it is not clear cut.Now discovered, the AIB 56's now have sk hynix hbm2 which doesnt clock nearly as high as ref 56 samsung hbm
AIB 64's are still samsung.
Works fine on Vega...Agree with the above on Xfire, so im not surprised AMD canned it
On the most part it worked fine with my R9 290X's it was only a few games that it didn't work, Mass Effect spring to mindWorks fine on Vega...
Hi Panos,
I am currently playing Destiny 2 and metro last light redux.
I have an lg ultrawide 2560x1080 144hz and I have to dial back some settings in these games to maintain the 90fps minimum I like.
I have a motherboard that has a plx chip so it is better suited to xfire plus I like the look of 2 cards.
I normally use 1 card until a new one is about to launch then get a second one that has been discounted when retailers are clearing their stock. I sometimes get second hand but with the used cards likely to have had a hard life in a mining rig I will be avoiding second hand this time around.
Hi Panos,
Haha, you're right. 60fps + the odd drop (negated by freesync) is fine for me tbh.
The 16GB HBM on my Vega Frontier Liquid goes up as far as 1150Mhz without issue. I've yet to test higher, but the Frontier with 8GB extra memory has clocked higher on the memory than any other RX Vega 64 I've used.
I've seen memory usage peak at 14GB on Call of Duty World War 2 at 4K max settings. The same settings would stutter on the RX Vega 8GB, unless you enabled High Bandwidth Cache and set it to 13GB or so.
Lol that pos actually manages to whore up 14 gigs of vram yet still look like something 5 years out of date? Something not right there.
That was the single player campaign btw, not tried MP.Lol that pos actually manages to whore up 14 gigs of vram yet still look like something 5 years out of date? Something not right there.
you have to see some custom bios some have madebut, but, the Frontier Edition isn't for gaming![]()
Evening. Has anyone here with a Vega 64 LC (the original AMD Liquid Cooled design) replaced the AIO cooler with a better AIO cooler? It could just be the weather but I'd like to reduce temps and I have my eye on some 1440p 144Hz monitors which means hotter compared to 1080p. I'm not interested in closed loops (yet) so really I'm wondering if products like the Alphacool Eiswolf 240 will be considerably cooler, or even possible.
IDK why someone could replace the cooler.
I can tell you how you reduce temps with these high temps. Set the card to Balanced or Power Save mode. I have done so even if I have the Nitro+ custom water cooled.
On Balanced Power doesn't burn more than 240W and on Power Save mode 178. If you are on power save mode and play something like Elite or EVE or generally space games, Strategy (EUIV), it will automatically switch to 80W mode without losing FPS.
Personally I am running the card on Power Save mode most of the time when I do not game graphic intensive game like Far Cry 5.
On WOT the Turbo Mode (1630/945 clock, 276W) and Power Save (1430/800, 178W) is just 15% less FPS. (difference between 100 and 115-120 fps so nothing).
Also consider to replace the thermal paste with Conductonaut or at least cryonaut.
Had one of the new Nitro+ and in less than 3 weeks the paste was rock solid.
Conductonaut drop the temps on the air cooler by 12-15C. Ofc with the waterblock+Conductonaut I do not see temps higher than 43C even heavily overclocked.
Liquid metal might be worth a go. I'd like some reassurance that it is possible to remove the AMD Coolermaster AIO but it seems like no one has done that and shared the process online. I'm halfway into the warranty period.
Hopefully all of this comes out in one piece... can anyone comment on this? Thanks.
I wouldn't bother changing the paste on the AIO. Why risk potentially damaging the card?Liquid metal might be worth a go. I'd like some reassurance that it is possible to remove the AMD Coolermaster AIO but it seems like no one has done that and shared the process online. I'm halfway into the warranty period.
