- 10 Oct 2006
You're absolutely correct.
By the way, the only reason they get less support calls is because no one will make any real applications for it. Any real application which could possibly need support will most probably be on Windows, Macs will only be utilised for dumbed down tasks like iPhoto or hipster crap like showing off garageband or something that's why they wont get any support calls.
Cant believe how brainwashed people are really. At least control the variables and have the macs using the same application as the PC, such as Adobe CS. If these brainwashed people still think the Mac will get less support calls then there is no hope really.![]()
My employer let’s you pick MAC or Windows/iPhone or Android.
I generally go between them I do think in general the MBP is a well built laptop but doesn’t justify the £500-600 premium over an XPS.
We saw similar to IBM the Macs caused a lot less hassle with lower support calls and a lower hardware failure rate, until the poor keyboards on the 2016 & 2017 MBPs. They are running the same applications mainly Microsoft Office and Adobe products. I use virtual machines on mine and cycle into work with it so mine gets well used.
Some folk run Windows 10 in boot camp exclusively as they don’t get on with OSX, they simply prefer the Mac hardware. It’s not a status symbol either as a few have covered up the Apple logo to avoid the hipster comments.
A good example of less issues is the XPS laptops, the killer WiFi card is rubbish so drops WiFi randomly, we now swap them out for an Intel card.
Going into my Windows laptop/Android phone year so will be interesting how I get on after a couple of years of Macs/iPhones.
