I've just picked up an Inno3D 1080ti X4 and have an odd issue with it. When I first turn the PC on everything is fine and for the first couple of benchmarks all is great and the card is fast. However after a couple of tests the scores plummet. For example running Firestrike in 3DMark I get a GPU score of 28k+ for the first couple of runs, but then it'll drop to ~15k, then ~10k.
I've used Afterburner and the Inno3D software and everything seems normal. GPU temps never get higher than 72 degrees, all clock speeds look good and there's loads of ram available. I've reinstalled the drivers, I've even done a clean Windows 10 install and still have the same problem.
My specs are: i7 8700K at 5GHz, Gigabyte Auros 7 board and 32GB Corsair RAM. I previously had a 1080 in the same setup with no issues at all.
Any suggestions?
Any suggestions?
