Caporegime
- 8 Jul 2003
- In a house
I hope you don't have to wait long for a replacement, and when you do, it works ok
What clock speeds are you at on the card? And how do you get +150w PL?I'm running pretty similar to you with a 1920X @ 4GHz and a Vega 56 on a 64 bios with 150% power limit enabled and haven't had any trouble with power draw using a 750W PSU. GPU power draw at the absolute maximum I've seen pushing the full fat 1.2V at 150% power limit was 330W and the CPU at full chat using 1.325V pulls 240W.
Pretty sure I'm about at the limit of this 850w psu here if I try to overclock the card. How much power are guys with overclocked setups running?
If I even set +1% the whole system locks up and If I set +50% PL without reducing the clocks from 1632 in p7 it also locks up. Same with lowering voltages at stock.Defined overclocking? Set it to +50% power limit and +4%-5% overclock. (use the vertical overclocking bar not the P states)
Open the overlay while gaming and let us know (or take a picture) of it.
At Turbo mode what are your clocks, power consumption and temps? You can see that using the overlay while gaming.
What PSU you have? Is it connected to the GPU with 2 independent 8pin power cables without spliters?
Turbo mode I'm seeing power round about 250w though it will occasionally spike down to 99w. The clocks are staying around 1510-1555 and the maximum temperature I saw was 70c and this without touching fan settings.
So you think I'm just out of luck on the old silicon lottery as to why it cant go much higher I mean temps are ok etc but as soon as I start fiddling with settings it seems to just not like it. Memory actually overclocks pretty good It's Samsung though.That is impressive for same clocks my Nitro+ at Turbo mode needs 276W.
Yeah spiked down to 70-80W are normal when cards aren't utilised
If going by the gpu-z or overlay then this only reports the gpu draw, so if you add 40w for the hbm and the power regulation this will put it to it's true power draw.Pretty sure I'm about at the limit of this 850w psu here if I try to overclock the card. How much power are guys with overclocked setups running?
ok yeah it will be the same as it's reported over the i2c bus.i'm using afterburner to report the power.
Highest clock speed that my card can get stable is around 1712 which is pretty low compared to most. Unlocking 150% power limit requires registry tweaks to the powerplay tables. I used this video for working out how to unlock the higher power limits.What clock speeds are you at on the card? And how do you get +150w PL?
Has anyone gone from a 980Ti to a V64?
What is the voltage in the hbm p-state 3 set to? What vddc does your card hold when under full load?Highest clock speed that my card can get stable is around 1712 which is pretty low compared to most. Unlocking 150% power limit requires registry tweaks to the powerplay tables. I used this video for working out how to unlock the higher power limits.
Day to day, I run it as P6 = 1632MHz @ 1050mV and P7 = 1672MHz @ 1075mV. Average power usage is around 240W and peaks at 275W as reported by GPU-Z. HBM runs quite happily at 1100MHz.
