- 6 Jan 2013
- Rollergirl
You getting one Pal?
I thought I had ruled it out, but then another thought occurred to me: One major reason I didn't buy a Titan in the past was because I didn't want to fit a custom block myself which would void the warranty of such an expensive card. However, if Zotac bring out a 2080ti with a block and a 5 year warranty option then it seems to have "accidentally" solved my issue.
I need to see benchmarks and decide, is the 2080ti the new Titan in terms of performance? That is, will it provide the same % uplift in performance that the Titans have traditionally provided over the previous gen xx80ti's? If so, I could be in.
