Its the nitro+ on airBecause I missed the discussion and seems these are my settings from above (but temp doesn't match)
Is this with the Red Devil on air?
Can you reset the Custom settings (click the button) and add my settings but leave the fan as it it.It's at 68c for the limit.
Its the nitro+ on air![]()
Feel safe to raise power to P6 1090mv and P7 1100mv to see how high it can go@Panos thanks a lot will give it a try tomorrow![]()
Thanks will tonight. I have another question in which bios mode do you set the card? What the bios switch does seems to be a bit confusing and hard to find any info on the SE version compared to the LE.Feel safe to raise power to P6 1090mv and P7 1100mv to see how high it can go![]()
You know forgot that this one exists
Mine is set to the right as you see the card upside down in the case.
I will try to find out and let you know![]()
Yeah its weird on the LE edition it was a way to set the card as overclocked or not but from what I see on Sapphire website for the SE version it is just standard vs uefi bios.
I will try also tonight just wondering if you knew it on top of your head![]()
No unfortunately but just switched it. Seems more power delivered on Power Save & Balanced
Hmm the card clocks the same..... Surely there was one power saving bios one not?
I am not sure on the sapphirre website they say that its only a uefi bios mode switch : http://www.sapphiretech.com/productdetial.asp?pid=6A72A3C3-DF09-4552-9091-792B1F45CB4D&lang=eng
Yes I was trying it last night actually because my card just never wanta to take more than 250w. Unfortunately it didn't work for power consumption but it does allow me to reduce voltage more at higher clocks than it was. Can get it to 1600 at around 1030mv or something.You know forgot that this one exists
@Lokken86 mate, with your PC turned off. Change the BIOS switch and try the overclocking settings gain
Looks like even at sapphire nobody knows exactly what those cards features are. They are still advertising their tool to check their fan despite the fact that it was removed the new version with Vega support month ago and never rereleased itHmm so the card by default is on Legacy mode not UEFI mode. Ofc my card doesn't have that button but a positional switch.
Cheers. I will have a play with the settings![]()
The issue definitely seems heat related though. Even though my card can stay at low ish temps, it's almost like it begins throttling at 60-65c.
Yes and I expected the default balanced or Turbo setting to change but they didn't. Maybe it wasn't working.Did you tried to change the bios switch position when you PC was turned off also?
Got it on member market but no I don't think it was mined with. I can double check the bios to see of it is the correct one though.Leave it to the "second" setting, and try overclocking with the settings gave you above.
I hope you bought the card brand new and not used one yes? Because if you got used from miner might be flashed.
Is a miners card mate flashed with the 250W bios.Got it on member market but no I don't think it was mined with. I can double check the bios to see of it is the correct one though.
