When will they be available in UK?, I'm on i7 3770k, and I am itching for an upgrade. Any solid info anywhere?
Last time I read it was October 1st.
You are comparing chips manufactured by GlobalFoundries 12nm process and Intel 14+++nm process.
The really interesting things will happen next year:
GlobalFoundries needs undefined time to fix its 7nm process;
Intel needs undefined time to fix its 10nm process;
while AMD will happily manufacture 7nm Ryzen 3 at TSMC 7nm process.
A friend of mine has a 2700x at 4.2 and that got upto 80c whilst running cinebench on a 280mm AIO.
It would melt at 5ghz, if it could clock that high in the first place.
Straying into argument territory here.
Temps above seem strange though, mine hits 69 degrees running blender @ 4225 all core.
Don't like being called a liar :/
Anyway, back on topic. 9900K is tempting me.
Does look pretty good, assuming it hits those speeds and doesn't melt your house.![]()
Yes I am, but only because of the stigma created on here and elsewhere on the internet.
Yes intel runs hot but lets not pretend AMD runs cool when running at anywhere near those speeds. Like I said, 4.2ghz under a 280mm hitting 80c in cinebench is hardly cool is it?
I hope this is one of the non-K CPUs as it has been delidded and has thermal paste:
https://forums.anandtech.com/thread...e-toothpaste-tim.2552726/page-5#post-39554360
@kitfit1 Ambient temperatures and case airflow also play a role, can't 1:1 your temps to a reviewer's temps.
Just run Blender on my own system, yes only the Quick benchmark, but even running the full fat one temps only creep up another 1c or so.
Run at 4.25Ghz all core clock with a single core boost to 4.34Ghz. As you can see, mine never goes above 74.8c. I would suggest the H1 50i Pro is a pile of "doggy droppings" Maybe peeps should actually be looking at this: https://www.overclockers.co.uk/ocuk...-liquid-cooling-upgrade-bundle-bu-098-tl.html
Been using the same AIO since i had my 1700.
Intel learned back in 2004 or whatever that chasing GHz was not a long term solution because of thermals and fundamental limitations. It sure has been a winning strategy for them in the short term though.Seems odd to me that 5GHz is still a thing. As far back as Sandybridge some people were hitting it. We're still looking at very few people owning a 5GHz capable CPU. Don't thank Intel for that we'd all be buying quad cores if AMD hadn't pushed them.
I think the majority are just glad to have an option to pay less rather than being held to ransom by Intel drip feeding performance in tiny increments.
After the 9900k where do Intel go next? 6GHz, not happening. Bigger dies, not likely they are already expensive. Glued together cores, a bit hypocritical after taking the mickey out of AMD![]()
