Looks great @The Craig - just remember the clean it at least every week!
@HungryHippos it's probably the same. It's likely your house was up before the building regs were in place. 30 mins is pretty standard for a kitchen but keep in mind the whole doorset needs to be 30 mins to have any worth. That means frame, hinges and door. If the walls aren't 30 min rated then it's largely pointless.
The house is around 1.5 years old, so I'd expect it would need to meet current regulations. I just read you can replace like for like, and I do not believe any of my doors are fire doors as things stand so should be fine. As a new house the walls will be simple plasterboard I doubt they would last all that long in a serious fire!
Typically 2 layers of plaster board is 30mins. Like for like is fine.
Part B of the building regs will give you the details if you're interested. It's free from the
.gov website.
snip
I love that new bathroom The Craig, any more details?
What size is your bathroom and how much did all that cost. Looking to renovate our current bathroom which is about 2.2m x 3.3m but as it's a flat I'm not sure what the limitations are.
Those are ones I have. The carpenter said I wouldn't need 3 hinges for them as they're relatively light :S not sure if he was fobbing me off or not but currently seem OK.Unsure if they are or not, the spec doesn't seem to say, this is the link to one of them: https://www.wickes.co.uk/Wickes-Geneva-Internal-Cottage-5-Panel-Oak-Door---1981-x-762mm/p/214699
They do say they require 3 hinges but that's OK all of my current ones are 3 hinged. Unsure also if the hinges can be re-used or not.
My current kitchen door does not appear to be any different to my other doors around the house.
Just for cleaning I assume? Cheers@The Craig Nilglass is your friend.
