That gate looks well built, do you have a guide that you followed?
Thanks, just looked at a picture of my parents (similar double sided/shadow box fence) and various different 1st pages of Google and seemed to turn out alright!
Great effort on the gate.
I don't see a router in your pics. Did you just use your mitre saw to make the lap joints?
hah 3 layers of tiles only in the walls of the bathroom... Which I've not done yet
You can only hear the drimaster running if you put your ear up close (with the fan on a high setting) when you're in the loft. Otherwise it can't be heard at all from beneath, it's suspended from a cable to the roof trusses, so no vibration/noise can easily be transferred.
Image of install here:![]()
It hasn't created any noticeable drafts, and mines installed in a narrow corridor, which is the worst kind of installation point (near walls)
In terms of humidity it has significantly reduced the humidity issues in the bedrooms backing onto the garage walls. If I leave the doors open will be around 60% measured from hygrometer, was previously 80+% (roughly)
-Humidity will still get high ish in the nights when sleeping, but will be resolved just by leaving the door open which suits our lifestyle (both at work all day). I expect the humidity to improve even more so when I get a door between the bedroom hall and the kitchen.
I've been installing roof lap vents in the loft the last week or so, as the non porous roof felt has been condensing a lot of water in it, due to the additional heat in the house with the increased insulation (which I made sure to leave gaps at the eaves!). I've since resolved this issue with roof lap vents thankfully, very poor quality old bitumen felt.
) The tiles are looking good! Also replaced the floor and shower seaped through the old layers of tiles a bit :XShower pipes are against is against brick if it makes a difference (old one was against plasterboard ..). Isn't tanking it just a bit belt and braces? Agree I'd probably do it if I DIYd it, but I dont have much knowledge on it tbh..Id probably have tanked the shower portion... Plasterboard and water are not a great idea!
Looks nice though, assuming they'll put trim around the window portion? Would be shame to have bare edge for sake of £30.
Looking forward to having a shower again!
Tiling done but all units etc still to go in. I've been sorting out the front garden this weekend.
Looks like a really tidy job but those lines around the cubby holes are messing with my OCD, should look better grouted. Sorry
What size shower tray did you go with looks a good size?
. Looks good in person trust me!
(not in too high up/noticeable a place)
It is grouted. Looks good in person trust me!
Electrics getting done today.
Shower screen been fitted but has a small internal scratch in it(not in too high up/noticeable a place)
Tray almost fills full wall at 1700x900,so pretty big!
I'll get pics up when it's done. Hopefully the end of this week. The fitter is taking longer than expected so getting my moneys worth![]()
Personally I would have centred the middle tile around the recesses but as long as it looks good and your happy that's all that matters
We did pretty much that with our 25mm tray, works really well. Although with a shallow tray you'll never have much of a step anyway.What height is the tray?, currently looking at the 1700x900x30 low profile trays and tiling up to them to give an almost wet room look.
Why do you say that? (it's out of shower and not from Victoria plum)I hate to say it but that Rad will be rusted out in 18 months...
