- 30 Sep 2005
How long did that all take?
Too long, and my body was broken at the end
Spent all weekend giving my car a full deep clean.
This was the process I used
1. Covered with TFR and left for five mins
2. Rinsed, washed, rinsed, washed
3. Claybar (autobrite clay with water, love this clay)
4. Machine polished (compound with red pad) 4 passes
5. Machine polished (polish with yellow pad) 2 passes
6. Machine polished (wax with black pad) 2 passes
7. Cleaned windows and any areas I'd caught with polish using Megs glass cleaner
Looks amazing. There was a few areas on the roof with light swirls which have completely gone. Close up it looks absolutely perfect.
Out of interest, roughly how much did it cost you in equipment from #4-#6 as I've played mine but am thinking of getting the gear to give it a proper compound / polishing.
Can anyone remind me the name of the device that stops water spots?
Towel.
Any recommendations on the best one?
What compound are people using then? Bought myself a machine polisher at the weekend and just used it with ultra deep shine by autoglym, but while it's done a better job than hand polishing there's still lots of swirls left.
Bearing in mind abarth paint is soft as **** is there anything people recommend?
