It's a beta without release drivers from amd/nvidia.
Nvidia has drivers for it. You cannot launch the game without them. Cannot speak for AMD but they are usually a bit slower.
Interesting.
Hardware Unboxed had similar performance with the Ryzen 4 core as the Ryzen 6 and 8 core, now i know from just turning off SMT on my 6 core the performance drops and there is much higher load on the CPU, like never below 90%.
If i had turned off 2 of the cores i know i would have had a huge drop in performance, the fact that Hardware Unboxed had pretty much the same performance on 4 core as 6 and 8 core is.... well its very strange.
The game GPU benchmark shows a very clear distinction between 4 core and 6 core, and even some with 6 core to 8 core.
HB they all look the same, that's usually telling of CPU benchmarking that doesn't actually put any stress on the CPU
I'm not too sure, gamegpu shows minimal differences between 1600x and 1800x.
There is a difference shown there tho, and between the 2600X and 2700X.
The main thing is they show a huge difference between the 2400G and 1600X, both run at the same clock speed.
HB don't.
I do find it odd, people are reporting all different things. Even on same hardware.
We need more people making videos
Even the i3 will be fine. I saw a YouTube video last night a guy was running 150fps with an 8600k with 2 cores disabled at 720p with the CPU at 100% load. The world doesn't implode when the CPU gets to 100%.well it does show how good a cheap i5 is for gaming.
Perhaps some have left the dynamic VSYNC thing on and so it is adjusting quality for performance rather than locking custom settings with sync off.
How do you make your video, I just get black screen from MSI afterburner, also how do you show graph etc with bench times.
the stuttering goes through the roof at 100% usage though, at least in my experience. I would consider bf5 unplayable with an i5 (4c/4t) or lower, might look okay on the graphs but not during gameplayThe world doesn't implode when the CPU gets to 100%.
