Does a standard debit card work? I don't have a clarity card and revolut doesn't have currency for Argentina?I used a Argentina address and my UK Halifax clarity CC.
Yes, and enter address of foreign country and press buy ... press and hold enter (I placed a book on the key LOL) and wait.
Does it work with the turkish store? Can only use my revolut card thereYes, and enter address of foreign country and press buy ... press and hold enter (I placed a book on the key LOL) and wait.
Not really, you can´t buy more than one digital game.This sounds like a good way to end up with duplicated payments!
Yes it does according to what I have read elsewhereDoes it work with the turkish store? Can only use my revolut card there
It worked currently enjoying the 85.99 version of nba2k19 for a cool 43 quid you're a life saver!Not really, you can´t buy more than one digital game.
Yes it does according to what I have read elsewhere![]()
Glad to hear!It worked currently enjoying the 85.99 version of nba2k19 for a cool 43 quid you're a life saver!
DON'T DO THIS.Guys, I know this sounds silly but there is a new and easy way to buy games, no VPN required! I successfully purchased both fifa and rdr2 from Argentina last night
All is done via the M$ site, select the country´s game ect and after you input your card details and address, click on "buy now" and keep the enter key on your keyboard pressed. This will cause the pop up error message to go in a loop. Have patience and it will eventually work. It can take 5-30 minutes for this to work. Full instructions are available on xbox-now.com![]()
DON'T DO THIS.
People are getting their MS accounts locked or banned for a couple weeks and then received a warning email. Microsoft is viewing it as an indirect DDoS attack.
Please state sources with this type of post.
Someone beat me to it also not as of I'm known for dubious postsPlease state sources with this type of post.
. Is this a forum rule? Next time won't bother, get banned.Someone beat me to it also not as of I'm known for dubious posts. Is this a forum rule? Next time won't bother, get banned.
Anyone know any new ways of buying from turkish store? That method I've seen people getting temp bans and really want the new pes for 18 quid?
Just tried the vpn and revolut method but it's not been going throughUsing a VPN doesn't get you banned, people were getting banned for the multiple submit button thing.
Is that the method using connectify or an actual Ethernet going to the xbox?VPN on your xbox?
Yeah just tried vpn to console and no luck and trying the turkish store and it's all green?Also check the live service status for the country you are trying.
https://support.xbox.com/es-AR/xbox-live-status ARS
https://support.xbox.com/tr-TR/xbox-live-status TRY
