I just skimmed that post, so I might have missed it, but from what I saw that was all about HDMI at 4k.That would be entirely unrelated to what we're hoping to determine.Multiple users on reddit and here have posted that there is no chroma subsampling at 3440x1440 120hz on DP1.2. A guy on reddit I talked to about it used this test to check https://www.geeks3d.com/20141203/ho...-chroma-subsampling-used-with-your-4k-uhd-tv/
If it's not:
DP1.2, 3440*1440@120 Hz, AND using G-SYNC
then it's not relevant to our question.
@JediFragger
@Vega
I very much want to trust your evaluations, that's just not very easy to do over the internet, when a third of male population is slightly color blind and half the male population tests their monitors with FPS games (compressed textures, lots of AA rather than sharp edges, limited color spaces).
What makes it particularly difficult to trust the "all is well" conclusion, is the fact that IF there is no degradation of any kind at 120 Hz, then the option to disable overclocking is technically pointless. Then Why?
Could you explain how you tested?
Did either of you use test images to surface banding issues (becomes quite apparent on a 6 bit panel), or use an image that is easily "ruined" at anything less than chroma 4:4:4?
No offense.
