Geforce GTX1180/2080 Speculation thread
22 Nov 2009
Under the hot sun.
Feel sorry for that card after he tore it apart :( Regardless of price it looks good and seems to be very solidly put together.
Indeed he should be shot for destroying it. :mad:
Mate that cooler is beefier than the one used on the Vega 64 Nitro+ and the GTX1080Ti Xtreme. Cards designed to deal with 330W power consumption (both).
And that make me thing that it will run very power hungry
11 Jun 2003
Hampshire
Wow, if true the two different SKUs thing is interesting. Could be all sorts, better chips for some AIBs / higher tier cards. Chips for NV only. For reviews. Maybe for an as yet undisclosed ‘Titan’ 2085 jobby.
Doesn’t necessarily spell doom, it could even be that the A’s are for us gamers and that the non are for some content creation card yet to be released.
It’s dissapointing though that it’s another thing NV aren’t telling us though (if true), I would have thought that’s something you bring up at the launch presentation. This whole release has been super weird imo.
EDIT : Just watched the tear down. Not only is that an absolutely stunning cooler, but it looks very well put together. Their best yet by a large margin.
Man of Honour
13 Oct 2006
Which is pretty much a given with the size of those cores the question is does it have the performance to match and can it adaptively manage power when not using the Tensor/RTX functionality that are part of why the cores are so big.
12 Feb 2009
It's likely to be around 80% faster than the Vega 64, so even if it hits 330 W, that's pretty reasonable in context. :)
11 Jun 2003
Hampshire
775mm sq, that sucker is gonna be HOT when it's all firing!! :eek:
They seemed pretty confident on presentation day. I’m reckoning there’s a chance the FE cooler does a very good job. What with the wattage figures and die size I’m probably wrong.
EDIT: and so many 2.5 - 3 slot coolers. You’re right mate, I’ll be quiet.
Permabanned
15 Oct 2011
Nottingham Carlton
Why they gonna slam Aio on it like instant like always...
Air cooling ?? Who cares :D Not had AC in gpu since eee cant remember had water on my ATI 4850 so how many eyars is that.
Besides he could always do Smash my RTX.com like they used to do :)
28 Sep 2014
Scotland
TSMC 7nm doesn't face delays though. :)
On the contrary, the process is so good, that AMD is releasing earlier than planned (by 6 months) some of their products. Like the Instinct Vega 20 cards. While EPYC Rome is succesfully been sampled for 4 months now.
TSMC 7nm will face delays if the yields are at 30-40% just like it had happened with both Samsung and TSMC's 10nm back in 2017 saw poor yield 30-40% that delayed Apple A11X chips shipments for 2017 Ipad models. Samsung and TSMC 10nm biggest customer is Apple.
https://techspecs.blog/blog/2017/4/5/why-the-new-ipads-are-delayed
AMD had been planned Vega 20 cards, EPYC Rome and Zen 2 3000 series APUs/CPUs to use both TSMC and GlobalFoundries's 7nm process to increase supply and demand but as you probably not aware Globalfoundries cancelled 7nm process last month mean AMD will have to use TSMC as only 1 source could see long wait for shipments or ship fewer chips.
Apple is TSMC biggest customer again on 7nm with A12 chip used 75% of 7nm capacity.
https://www.eetimes.com/document.asp?doc_id=1333615
I don't know what will happen in 2019 as it seem every company go to TSMC 7nm, Intel could be one of customer outsourced future chipset or low end CPU production to TSMC 7nm when both Intel 10nm and 14nm faced delays, shortage, poor yield or full capacity.
30 Mar 2010
Under The Stairs!
Yeah. That is going to be funny. Especially when people are pre-ordering but they have no idea if it will be Normal SKU or OC SKU.
Which reminds, Nvidia applying Intel tactics here with the "K series" but without letting clearly the users knowing what they buy until GPUZ is used....
Said at the very beginning there was going to be a lot of flipping on heat output.;)
Can't believe he destroyed that cooler, but more disappointed he's on the nda list, now we don't know what's what with the differing chips because they are obviously not allowed to report it as it's under nda(and some said the nda was normal practice coz they signed one at work:o), tbph, whole PC gfx scene is leaving a severely sour taste...
Caporegime
18 Oct 2002
Ireland
Be interesting to see FE temps vs the various other cards, 2 slot vs almost 3 on some cards. And vapour chamber vs what seems to be basically heatpipes and regular aluminium fins on others.
8 Nov 2006
London
An explanation of dlss from hardware unboxed says there are two modes.
The first mode works by hitting the resolution you want by upscaling a lower resolution image. This is likely the mode that gives performance uplifts.
Then there is the 2x mode which is basically intelligent super sampling. So renders at the resolution you want but uses information from a super sampled image created using the tensor cores (ground truth is a 64x super sampled image).
bru
bru
21 Oct 2002
kent
I believe you do have a 1000W platinum PSU yes? So take a deep breath plug the third connector to it, and don't turn on the central heating this winter.
You should be OK :p
Another good service by Nvidia. You warm your house while playing games during winter. No need for boiler and gas bills :p
Yet another thing they have beaten AMD at then, they heat your house better now as well. ;)
2 Jun 2016
UK
From earlier in the thread, it appears to be quite simply any overclocked card has an "A" chip (incL FE). Reference cards are "standard" chips.
