I'm having a nightmare with it so far.How's the in built fan hub? my grid v2 seems to be broken.![]()
I was hoping for that but I just can't get it to work I've spent hours on this problem and I can't figure it out so I'll need to buy some fan speed reducers.
Same here, especially that crosshair 6 has only one internal usb 2.0 and I need more. Besides onboard fan control is not great and you can't control fans based on the water temp.My plan is to take the phanteks fan hub out and use a Corsair commander Pro.
That a very nice build cliffy I would love to go hardline looks very difficult to do,I've gone for soft hose as I'm lazy
Got a email from a tech guy at phantek asking me to show how the fan hub is wired up so props to them support so far has been exellent.
No cable you need to buy one only the bracket Inc.
As for the fan hub,what I've worked out so far is.
1/ Sata cable to psu.
2/ 4 pin from the hub to cpu header.
3/ Cpu cable to the white header on the fan hub.
Had to order a flexible internal USB 3.0 extension cable as the stock one interferes with the cable tidy tray to much,apart from that I'm very happy with this case so far,being able to stealth your cables is excellent.
Would a nemesis 420gts fit in the front of this?. It's 153mm wide
