Caporegime
- 13 May 2003
- Warwickshire
Hi all
About 18 months ago we had a new bathroom installed and it looks great, with its fantastic unremovable tiled bath panel maintaining the clean lines
However we've recently been experiencing slow drainage from the bath, so we used a plunger on the waste, which worked great at freeing up whatever blockage existed...
However, I've just noticed a dripping coming down from the light fitting underneath the bath when it's draining.
I don't really want to rip off the bath panel as it's tiled in, and making it look the same as the surrounding area with new tiles and with the grout and silicone colour will be a nightmare.
What are my options here? I have no comeback with the installer really, since the plunging has clearly caused the leak.
I might be able to access the waste from the room underneath, but that would create holes in the ceiling and a whole load of mess, and I'm not even sure that the waste pipes will be accessible from underneath as they may run above the bathroom floor.
My home insurance doesn't cover plumbing issues.
Any thoughts are gratefully received, thank you.
. However we've recently been experiencing slow drainage from the bath, so we used a plunger on the waste, which worked great at freeing up whatever blockage existed...
I shall follow this thread closely
