Lolsame. my 2080ti is getting choked out by my 2600kAnd Ryzen isn't an option for gaming only.
What gpu are you using?Thanks for the link. Actually it highlights that something is wrong with my system.
https://www.guru3d.com/articles_pages/amd_ryzen_threadripper_2990wx_review,30.html
Looking there, the 2600k (I assume stock?) is getting a score of 6,000 points. When I run timespy, I can't break 4k! and that's running at 4.6ghz. How can I check to see what's happening?
2080ti as of a few days ago (waiting on 9900k) but even with the 980ti I had been using, the CPU scores are similar.
The score for the 2600k they show in the graph is the combined score, not the cpu score.
"Ryzen isn't an option for gaming"
Well I dont seem to have any issues. Your loss, I guess!![]()
Hmm, I wonder how the title on the chart got cropped off. All this chart shows is that if you are GPU limited it doesn't really matter what CPU you have.For context this graph shows average frames in rise of the tomb raider at 1440p on a gtx 1080.
Edit: it also shows that at 1440p on a 1080 at the settings used the game is gpu bound since every cpu offers similar frame rates.
+1 to this, its laughable really...
Lets be honest now, if your running a 2600x or 2700x and playing at 1080p with a 1080 / Vega 64 / 1080ti / 2080 / 2080ti you are going to get acceptable frame rates, if your monitor is 1080p 60hz you are going to cap the frame rate on pretty much anything you play.
Same at 1440p, only at 4K do some of the cards struggle, 1080 / Vega 64 and to a lesser extent 1080ti / 2080, 2080ti is going to basically max any resolution upto 4k if your running at 60hz, as soon as you step into the higher than 60hz arena, the CPU becomes a bit more relevant, especially at the lower resolutions like 1080p.
If your buying a Vega 64, 1080, 1080ti, 2080, or a 2080ti to game at 1080p 60hz your doing it wrong, if your aiming for 1080p and high hertz then your still fine on a Ryzen chip as your still going to be getting high fps in most titles, yes you might be 10% slower than an 8700k but if your hitting 140fps and the 8700k is hitting 160fps are you really going to notice those 20fps?
I find it hilarious that people often dont even bother with a decent monitor but will claim a chip inferior cos it cant push their GPU at 1000fps, even though their monitor can only handle 60fps etc.
Ironically the monitor is probably the most important part of any Gaming PC setup, as that is the thing you are spent 100% of the time staring at, in all honesty i build the spec of my PC to the monitor i use, pick the monitor first and then pick decent components to compliment it.
The amount of trolls on forums who have a high end Nvidia card but still run at 1080p is laughable, there is many like this.
And as we all know once you go to 1440p and then to 4k your CPU becomes less of a factor anyhow.
I would even go as far to say if your running a 1080ti / 2080 / 2080ti then unless your using a 1080p 200hz+ monitor you dont know what your doing, you should be at a minimum on 1440p 144hz![]()
Whilst most of what you say is valid, you need to remember that some people aren't completely focused on value for money and instead just want the best available. Obviously, Ryzen is perfectly valid for gaming but it's not the best choice for everyone.
Yeah if I was a "hard core" gamer I would have gone for the i5-8400. I'm not so I value the slightly better multicore performance of the Ryzen chip I bought in windows, which is where I spend most of my time.
End of the day there is on average 8% difference between 2700x and 8700k in gaming,
