OcUK Cinebench R15 benchmark thread
No screen shots but getting the following.
i7 8700 (non K), Gigabyte Z370 HD3P
32gb Kingston Fury 2133 memory stock timings (only paid £240 new)
1420 CPU speed in Cinebench (seen it drop just under 1400 at times)
Undervolted, CPU-Z was showing 1.008v, all 6 cores were on 4.3Ghz
Max core temps were 56c in heat wave with Silverstone FT-02 and Arctic i30 with all fan profiles silent in BIOS.
Does the above sound ok for stock 8700? Guess I should really post screen shots.
Yes, it looks about right.
Have a look at this page. Your multi-core result is a bit higher. (The scores are detailed from the 4th table onwards.) https://www.cpu-monkey.com/en/cpu-intel_core_i5_6600-523
Thanks for that looks like mine is good, I am now getting:
same price as my 1950X ;)
Yeah but one of us is a regular Joe running his CPU's on silent (and I mean SILENT) air cooling, while the other is a benchmarking guru who knows his way around a liquid nitrogen cooling setup - I saw you winning a benchmark contest on youtube. ;)
You probably have more CPU's in your cupboard than there are keys on my keyboard! :D
that is true.but the threadripper on water at pleb grade clocks would perform around same as your dual xeons :) i am not sure about air as i dont use air on the bigger cpus.
i think i have just over 450 cpus at the last count
Damn 450 cpu's! You could build an impressive CPU wall mosaic! :D
Yeah a TR 1950X at 4Ghz will score about the same, though sold listings on FeeBay show all going for £525+, so only you could get it for under £400. :p
I posted it on here, everyone had the chance
