Try the beta program and if it happens again then return it.
I probably just pop in into the Apple Store tomorrow after work and see if they can do any diagnostics on the phone.
Its rebooted again
One think they will ask you have you resetI probably just pop in into the Apple Store tomorrow after work and see if they can do any diagnostics on the phone.
Its rebooted again![]()
"You're holding it wrong"
I will leave it at that.
DFU restore and setup as new.
Before doing that are there any logs with “panic” in the name under settings - privacy - analytics ?
If you go into the apple store get them to log that down, panic logs are usually an indication of a hardware problem but were told to restore the phone and setup as new and test before swapping the device
Well she still has the phone and it’s still in one piece lol.She’s going from iOS to iOS, So she should be fine. And Face ID is amazing, and so easy to setup and use.way better than Touch ID.
has the protector come as I keep looking at these then I keep looking at Spingan for the edge to edgeI’ve had my XS Max for 2 days now and really love it.
I’ve just ordered the OMOTON glass screen protectors (3 pack). I’m using the Apple leather case and as always with these cases, it’s a perfect fit.
Yeh 256gb XS, sorry forgot to mention that.
I'm still thinking purchase outright from Apple and go down to a sim only tariff will be cheaper overall though...?
Plus, anything to avoid O2! Their roaming data rates are horrendous, plus 4G is no where near as good as EE for example.
