OcUK Staff
- 26 Nov 2014
- Stoke
Now available for preorder are the hotly anticipated Phanteks Revolt X Power Supplies. These are ideal for anyone planning to build a dual system into the Evolv X (or any other dual system compatible case such as the Mini-XL and some Lian-Li cases to name a few), as they enable you to power two motherboards with one unit, using their patented state of the art internal PCB. Added to that they are 80 Plus Platinum Certified, fully modular, with 12 years warranty and based on the Seasonic Prime Ultra platform. Essentially, all the right things
Available in 1000W and 1200W flavours, I have VERY LIMITED initial stocks arriving, so if you're interested, I'd suggest preordering ASAP.
Phanteks Revolt X 1000W 80 Plus Platinum Modular Power Supply @ £214.99 inc VAT https://www.overclockers.co.uk/phan...-platinum-modular-power-supply-ca-086-pt.html
Single PSU for dual motherboard systems, control each motherboard independently, manufactured from premium materials, 80 Plus Platinum certified
Only £214.99 inc VAT.
ORDER NOW
Phanteks Revolt X 1200W 80 Plus Platinum Modular Power Supply @ £234.95 inc VAT https://www.overclockers.co.uk/phan...-platinum-modular-power-supply-ca-085-pt.html
Single PSU for dual motherboard systems, control each motherboard independently, manufactured from premium materials, 80 Plus Platinum certified.
Only £234.95 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
