- 23 Mar 2011
A few options.. if you're already using the holesaw you get with the fittings you can put 2 seperate holes above each other one behind the TV and one behind the unit then guide the wires through there to hide them.
Or what I did in the kitchen which wasn't crazy expensive was having a plug socket placed behind the TV which hides it all (I use multiroom or netflix so no need for antennas).
Or I guess your last option is trunking.
Bear in mind most people, myself included tend to mount things too high. You could have it just floating above your unit which I've done with the TV I'm using as a monitor, then as long as the cables are bunched together and there's only a 3" gap you can barely see them anyway.
I May be ok just to dangle them down then as I don't want it much higher than you have described. The issue right now is that it's currently on a full sized side board and it is just too high really. So getting a lower unit and setting it just above should be spot on!
