5.1 hits harder on a proper benchmark lol, highest is 88c with the increase in voltageHow are temps at 5.1?
Edit - derp, is that the temps in the screenshot? I saw 4801.15MHz and my eyes just flew past it.
Looking good!
Looking good!
what temps are you getting doing a prime run ?5.1 hits harder on a proper benchmark lol, highest is 88c with the increase in voltage
cpu is OEM tray from you guys, Gskil trident z 4266mhz (4 sticks)
Whats the consensus on the Solder? Has it sorted out the temps?
You can watch Der8auer explain in detail the 9900k heat issue.Whats the consensus on the Solder? Has it sorted out the temps?
that was prime, 5.1 is defo hotter, pitty it needs a .05 voltage jump, 88c is maxwhat temps are you getting doing a prime run ?
Is that non avx?that was prime, 5.1 is defo hotter, pitty it needs a .05 voltage jump, 88c is max
Thats a shame, still it seems like its a bit better than paste at least for the guys who wernt willing to delid its better i guess.No...
Was before I sorted my ram etc , will do another run tomorrow, as I can near pull that score with 5gzWere you running other things while doing that CB run? Looking at benches online from reviews, 5.1 should be scoring 2200 ish.![]()
Ah okay. I'm not seeking proof or anything, i was just wondering why it was so different to the other scores i was seeing. If you know you can get it thats good enough for me.Was before I sorted my ram etc , will do another run tomorrow, as I can near pull that score with 5gz
Thank youI can post all my bios shots no issues, started just 1.3 all cores 50x, is ac 0.01 dc 0.01
Agreed. No way would they have used solder TIM if they could have used regular TIM.
That said, not every 9 series is an inferno.
Buying a CPU has always been a lottery.I don't know what's going on... has buying a CPU now become a lottery as to whether it runs crazy hot or not?? Or is it simply early batch issues? Unacceptable whatever is happening.
