- 30 Aug 2018
Is the info in this guide still relevant?
Probably not so much, the basic concepts will be largely the same though.Is the info in this guide still relevant?
TyProbably not so much, the basic concepts will be largely the same though.
very nice guide, will help me a lot even though im still pretty confused![]()
Thanks. I have been thinking of updating it but the underlying principles are largely the same still.Great guide, very interesting reading.
Would be lovely to have an update to this guide (not sure how much has changed, but presume there are now some new differences, etc).
i am overlooked in the past, sometimes simply by leaving voltage on auto in the bios and just upper the multipler - and sometimes running a program to test the system stability (unigine vallley benchmark). I am about to get a 3rd gen ryzen - I gather that AMD has software called Ryzen master - but as I have never used it I don't know much about it. Perhaps this thread could mention that or can I have some advice should I use that the OC my Ryzen rather than manually in the bios or using the mobo utility software.Thanks. I have been thinking of updating it but the underlying principles are largely the same still.
So I'm toying around trying to overclock my Asus Rampage extreme board and 5960x.
I can overclock the machine no problem in the AI suite software. I've managed to push the machine to 4600 MHz with a 1.33vcore. The machine works fine in windows, Asus stress test and prime95 is fine and all temps below 78c. But when I set it to default and try and reboot, or configure it direct from bios the machine won't post. And it goes back to the default overclock?
I'm honestly lost for what to do?
Furthermore my memory seems to default to 2133mhz rather than the 3000mhz it claims to run at. I've selected the slower timings from the xmp profile drop down? The machine instantly turns off when I tell it to save. Hangs then loads a default profile?
Can anyone help me out with some guaranteed settings for my Kingston please?
Thanks,
Adam
