- 29 Jan 2003
Still a work in progress but here's mine so far - need to add in braided cables and tidy it up a bit. Apologies for the low quality pic and glare
anyone know if the cryorig A80 28Omm aio will fit in this and where would be best place, side or top. thanks.
I’ve had a Kraken x62 mounted at the top. It will fit and work but a fair bit is covered by the mounting panel so not completely allowing air flow to flow unrestricted. Would be better with a 360 rad mounted to the top.
Considering another top panel
slots over covering the whole lot it’s not ideal for a 280 rad I feel.
Just my view.
@Silent_Scone can you tell me how your fans are setup? Push/pull.
I really want this case but I'd just be getting a AIO for the CPU which seems like a waste. I'm a bit nervous about taking about the RTX. Even then, I've never done WC so anything past AIO's, I'd be uncomfortable with.
What do you think of this config. 3xside intakes. Kraken X62 AOI top mount exhaust. Vert GPU (per benefits shown by Gamernexus review). It's basically their config but the AIO and top exhaust should give me a cooler GPU temp and over all temps.
Does anyone know if the Cablemod vertical GPU bracket works with fans at the bottom of the case?
I'm thinking of trying to sell my Phanteks Evolv as the air flow just isn't good enough and i was wondering if the O11 Dynamic would be an improvement? I know there is the Air version but i just dont like the look of it.
